Reading and writing an USB with KL46z
2,323件の閲覧回数
juanignaciotroi
Hello.
I am using the KL46z and currently my main objective is to be able to communicate with a USB stick, using the via the USB controller that this boards comes with.
I'm wondering if there is any material or application sheet that you can provide me in order to make simpler the delevolpment. In particular, I'm looking foward to an application that uses Processor Expert.
Kind regards,
Juan Ignacio Troisi
ラベル(2)
2 返答(返信)
2,118件の閲覧回数
mjbcswitzerland
Specialist V
http://www.utasker.com/kinetis/FRDM-KL46Z.html
http://www.utasker.com/kinetis/TWR-KL46Z48M.html
Various composite possibilities and USB simulation, as well as memory stick (and memory stick firmware loading)
Doesn't use PE though, so maybe no use to you.
Mark
