Question about flash memory
1,286 次查看
dineshbabu
Hi everyone,
   I am new to codewarrior 10.6 and I am using MkV10Z32VLC7 controller. I have a question about flash memory.
 1)  how to store the data in flash memory?
 2)   What are the things should we change in component inspector during the store data in flash memory?
1,139 次查看
kerryzhou
Hi Dinesh Babu,
   Please refer to this document:
Relocating Code and Data Using the CW GCC Linker File for Kinetis
This document will solve both your two questions, you just need to modify the .ld file, then refer to the document :chapter 5) Relocating Data, it's clear to understand.
Wish it helps you!
Kerry
