Purchase the TWR-KV58F220M
1,919 次查看
pietrodicastri
Senior Contributor II
Good morning
I want to purchase the TWR-KV58F220M. The answer I get is:
The requested part number  TWR-KV58F220M-ND is a restricted part and unfortunately we are unable to supply this requested part number on your purchase order.
And what to do???
Thank You
Pietro
标记 (1)
1,807 次查看
chris_brown
Hi Pietro,
I think you may need to contact Mouser directly about this one.  TWR-KV58F220M-ND sounds like the wrong part number.  It looks to me like that would be a part number meant for alpha customers and not the general market.  TWR-KV58F220M (without the '-ND') is what the part number should be.  You could also try buying directly from www.nxp.com.
Chris
1,807 次查看
pietrodicastri
Hello Chris
The part number is from Digikey. I am trying to get from Mouser.
The suggestion to have from nxp is valid. I will try to progress on ..
Thank You
Pietro
1,808 次查看
chris_brown
Hi Pietro,
Chris
