Programming Manual
Programming Manual
4,150 次查看
markusbraitner
I'm currently evaluating K60 using a TWR-K60D100M Tower System. Is there a programming manual (showing which ASM commands are available etc.) available from Freescale for this kind of processor? So far I've only found Data Sheets and Reference Manuals on the Freescale website...
Kind regards,
Markus
标记 (4)
3,693 次查看
Carlos_Musich
Hi Markus,
The Kinetis K60 has an ARM Cortex M4 Core, all the documentation related to the core is provided by ARM. Kinetis Reference Manuals and Datasheets provided by Freescale contain information about the peripheral modules.
In the links below you can find information that may help.
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0553a/CIHJJEIH.html
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0439b/CHDDIGAC.html
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0439d/DDI0439D_cortex_m4_processor_r0p1_trm.pdf
Carlos
3,694 次查看
Carlos_Musich
Hi Markus,
Carlos
3,694 次查看
frank涛李
Hi Carlos,
Thanks a lot.It does help me!
Frank
3,693 次查看
markusbraitner
Hi Carlos,
thank you for your fast and helpful response!
Greetings,
Markus
