Programming K64F board by drag and drop bin./ hex. file
ソリューションへジャンプ
1,882件の閲覧回数
grochal7
Hello!
I have one question.
If I programmed my K64F board by using bin. or .hex file and "drag and drop" method will all flash also be erased?
Regards!
ラベル(2)
1,693件の閲覧回数
jorge_a_vazquez
Hi Tomasz Sobiech
It will depend on the OpenSDA debugger interface. Most of the application perform a mass erase before flashing your program.
Hope this helps.
TIC
1,694件の閲覧回数
jorge_a_vazquez
Hi Tomasz Sobiech
Hope this helps.
TIC
