Processor Expert SPI
2,771 次查看
laonia
I'm trying to configure SPI Master mode via Processor Expert on CodeWarrior. I'm wondering if it is possible to configure the chip select pin as a general purpose GPIO and manually set this pin when I want to send a message. Currently, what I'm seeing in the generated code is that chip select is automatically updated by the send message function.
Thanks!
2,744 次查看
JRoberto
You would have to do many manual adaptations... On my personal opinion I'd make my own SPI code.
2,751 次查看
JRoberto
Hi @laonia
What MCU are you using?
Unfortunately Processor Expert can't make the settings you want.
2,750 次查看
laonia
Hi JRoberto,
I am using KEA128. In this case, if I would like to import the KEA128 library from S32 Design Studio, is there going to be any conflict with the generated code from Processor Expert? Or is it better to just write my own code for the SPI communication?
Thanks.
2,745 次查看
JRoberto
