Power factor calculation for metering application
1,781件の閲覧回数
bharathpoonja
I have been using the metering library on KM14Z board. Currently I am facing problem in calculating the power factor using the Filter based algorithm of metering library. There are no API's available to calculate the power factor, therefore I am calculating it by dividing Active power with S(VA).
PF = P(Watts)/S(VA).
This calculation gives me wrong results. Could someone guide me on this issue.
Thanks in advance.
1,643件の閲覧回数
xiangjun_rong
Hi, Bharath,
In my opinion, the power factor is an angle, so it should be arccos(P/sqrt(P**2+Q**2)),P is active energy, Q is reactive energy, do you use the formula to compute it?
Xiangjun rong
