Possible BUG REPORT against 5.0 USB Stack, file usb_audio.c, at line 767
979 次查看
johnstrohm
In file Freescale_BM_USB_Stack_v5.0/Src/usb_core/device/sources/classes/audio/usb_audio.c, at line 767, you have (reformatted for readability):
    error = audio_obj_ptr->class_specific_callback.callback((uint8_t)GET_CUR_COPY_PROTECT_CONTROL,
                                                            audio_obj_ptr->current_interface,
                                                            data,
                                                            size,
                                                            audio_obj_ptr->class_specific_callback.arg);
EVERY other call to the class_specific_callback that involves audio_obj_ptr->current_interface is of the form:
    error = audio_obj_ptr->class_specific_callback.callback(audio_obj_ptr->current_interface,
                                                            cmd,
                                                            data,
                                                            size,
It appears to me that the call at line 767 is incorrect, and should instead be:
                                                            data,
                                                            size,
标签 (2)
标记 (3)
864 次查看
Jorge_Gonzalez
Hello John:
It seems you are correct, thanks a lot for reporting this. I will report it to our USB stack developers.
Regards!
Jorge Gonzalez
