Position-Independent Code example
4,123 次查看
publius
Does anybody know where I can download the code example discussed in AN5163 "Load Position-Independent Code (PIC) on a Kinetis Platform Using the IAR EWARM Compiler"?
3,584 次查看
Hui_Ma
Please download the AN5163 related software from here.
Wish it helps.
Ma Hui
4 回复数
3,584 次查看
vlastimilsetka
Hi, is it something like described in AN5163 "Load Position-Independent Code ..." also possible with GCC? There are -fPIC anf -fPIE gcc options, but it seems these are intended for something a bit different.
3,584 次查看
bobpaddock
Senior Contributor IV
The short answer is 'No'.
3,585 次查看
Hui_Ma
Wish it helps.
Ma Hui
3,584 次查看
publius
