Porting Code from MK20DX256VLH7 to MK20DX256VLL10
2,250 次查看
SilentBob
we thinking about the port our project to the MK20DX256VLL10. (https://www.nxp.com/part/MK20DX256VLL10#/)
Apperently this MCU has only one 16-bit timer.
The MCU that we currently are using (https://www.nxp.com/part/MK20DX256VLH7#/) has 13 16-bit timer.
Is that correct that the VLL10 has only 1 timer?
3 回复数
2,227 次查看
jingpan
Hi @SilentBob ,
I'm not sure which timer module do you mean MK20DX256VLL10 has three FlexTimer and one LPTMR.
Jing
2,222 次查看
SilentBob
I'm using these timers with the MK20DX256VLH7:
Timer
1
PIT0
2
PIT1
3
PIT2
4
PIT3
5
FTM0
6
FTM1
Would that be possible with the VLL10?
2,208 次查看
jingpan
Hi @SilentBob ,
Yes, no problem.
Jing
