Placing & executing functions from RAM
2,375 次查看
VictorLorenzo
How can I do for locating/placing several functions in RAM while keeping the rest of the code in FLASH?
Thanks, Victor
2,090 次查看
VictorLorenzo
I just forgot to say I'm using CW10.4 with GCC. Thanks Lei Mao for your replay.
There's one AppNote at http://cache.freescale.com/files/32bit/doc/app_note/AN4695.pdf which deals with in-software flash programming that also addresses RAM code location. All credits an many thanks to Enric for pointing me to this note.
2,090 次查看
VictorLorenzo
2,090 次查看
leimao
you can see IAR k60 example. use __ramfunc to define a function in RAM. good luck
