PIN MUXING TOOL
PIN MUXING TOOL
2,260 次查看
abulhasan
     We are using Kinetis K40 and going to design a new PCB using Kinetis K40. So we need PIN MUXING TOOL, supports the processor of Kinetis K40.
Thank you in advance
Abulhasan
标记 (4)
1,456 次查看
vicentegomez
I am not sure if you are looking check the pin muxing but you can use the solution advisor on the following link and get a excel file(csv) with the pin options
http://freescale.transim.com/solutionadvisor/SolutionAdvisor.aspx
I have attached the file for the MK40DN512VLQ10 device
I hope this will help you.
