PFlash_Program problem
1,266件の閲覧回数
billchang
I found a problem when I kept someone else's handover program(Use KEA128).The program used PFlash_Program this function, but the program did not declare this PFlash_Program function, but the use of CW V10.7 compiler will only produce a warning without error? Why?
1,199件の閲覧回数
kerryzhou
Hi Bill,
  If the CW compile have no problems, your PFlash_Program must have been declared before. You can search it.
  If you still can't find it, you can send me your whole project, I will help you to check it.
Kerry
