PC don't see USB
PC don't see USB
xamuk
Hi! Please help me with my problem. I have self made board with MK22FN512VLH12. I have problem with USB. If i run USB examples, then my PC don't see my board. All code traced in debug mode without errors. My board based on FRDM-K22F. What could be the problem?
Labels (2)
xamuk
I solve this problem. I don't connect VREG pin to VBUS  :smileyhappy: Thanks!
kerryzhou
Hi Dmitriy,
    That's very good to hear your problem is solved, and thanks for your hardware problem solutions sharing.
Jingjing
kerryzhou
Hi Dmitriy,
    What the USB example you are using?
    Did you also try the FRDM-K22F board and run the USB code in your PC?  Whether this board can work ok on your side?
Jingjing
