Open SDA MSD has 125MB space?
2,730 次查看
arthshah
hello,
i am using FRDM-KL25Z board.
there is a Open SDA port when i hook up my board It's show frdm-kl25z as a MSD and there is 125 MB of space?
what is these 125MB of space?
2,605 次查看
BlackNight
It just shows something so the host is able to send a file. It could show 128 KByte, but that would not make things any different, or the host might reject it as 'too small to be used'.
4 回复数
2,605 次查看
BlackNight
Hi Arth,
it is only 'virtual' and not real, and you won't be able to use it to store files with that size.
Erich
2,605 次查看
arthshah
hii Erich,
thanks for reply.
if it's not real why it's show 125MB of space?
2,606 次查看
BlackNight
2,605 次查看
arthshah
hello Erich,
thanks for reply.
