OTA Update procedure for K32 L2B
regino_vega
Hi.
I want to know what is the best procedure to update, Over-The-Air, an application running on K32 L2B.
I'm planning to use a cellular communication module to download the update file from a server, using UART to communicate with the cellular module. What are the steps I must follow to write and run this update on K32 L2B?
Best regards.
jingpan
Hi Rigino,
Please see the OTA application note AN12649. https://www.nxp.com/docs/en/application-note/AN12649.pdf
Jing
