No SPI Chip Select option in SynchroMaster component of Processor Expert for K60DN512xxx10 MCU
1,691 次查看
dkarthik
There is no chipselect option in the SynchroMaster Component. It uses Serial Master LDD Component internally in which the chipselect is set to 0. Does anyone know how to enable and set pin for chipselect in the SynchroMaster component?
Thank you,
Karthik
     This is SynchroMaster Component Properties        It internally uses LDD SPI Master component in which there is chip select = 0
标记 (3)
1,465 次查看
ZhangJennie
hello Karthik,
please use SPIMaster_LDD which can do chip select.
this answer is for you, if it helps, please click on "correct answer" button. thanks!
ZhangJun
