New to Kineties
New to Kineties
narreddiprakash
Hi Sir/Mam.,
                    As a new one to kineties, I want to know about K64 controller in detail. So, please guide me to get know about K64 controller and how to start a project in FRDM of K64.
Regards.,
Siva Prakash Reddy Narreddy
kerryzhou
Hi  Narreddi Siva Prakash Reddy,
    Welcome to use the FRDM-K64!
    For K64 detials, please refer to the reference manual and datasheet:
Reference manual:
http://cache.freescale.com/files/microcontrollers/doc/ref_manual/K64P144M120SF5RM.pdf?fpsp=1&WT_TYPE...
Datasheet:
http://cache.freescale.com/files/microcontrollers/doc/data_sheet/K64P144M120SF5.pdf?fpsp=1&WT_TYPE=D...
sample code download link: www.freescale.com/ksdk
Please download the KSDK 1.3.0, then refer to the KSDK document to run the project, after you install the ksdk1.3.0, you can find the KSDK document in path:C:\Freescale\KSDK_1.3.0\doc
The K64 sample code can be found in path:C:\Freescale\KSDK_1.3.0\examples\frdmk64f
Wish it helps you!
If you still have question, please contact with me!
Jingjing
