Need Drop in Replacement for MK11DN512VLK5
sanjaydath
We are currently using MK11DN512VLK5 in our project which has 512KB Flash and 64KB SRAM.
Now we are in need of high memory (both Flash and SRAM) microcontroller which should drop in replacement for existing microcontroller.
Request you guys to suggest if there is any microcontroller available which suits the above need.
kerryzhou
Hi Sanjay,
This is the duplicated question for:
Please refer to my reply in your above post.
Wish it helps you!
Kerry
