More than three DAC.
1,373件の閲覧回数
simoneacciarito
Hi everybody. I need to use an MCU with more than three DACs. Can you tell me if there are MCUs in the Kinetis family with this requirement? Thanks in advance.
1,321件の閲覧回数
mjbcswitzerland
Specialist V
Simone
I don't think that there are more than 2 (12-bit DACs) in any of the Kinetis parts.
However, you can also use PWM outputs to generate DAC outputs (add an R/C filter to create the analogue signal)
Mark
PWM:
http://www.utasker.com/docs/uTasker/uTaskerHWTimers.PDF
ADC/DAC:
http://www.utasker.com/docs/uTasker/uTaskerADC.pdf
