Microcontroller's reset pin behaviour when chip is blank
2,094件の閲覧回数
yvesb
HI all,
I noticed the reset pin gives a periodic pulse when the chip has never been flashed.
Is this a normal behaviour?
Yves
1,918件の閲覧回数
egoodii
Senior Contributor III
Certainly!  The 'invalid' PC/SP startup-values fetched from blank Flash memory quickly lead to 'nested hard faults', and the default power-on behavior for that condition ends in a hard reset, which starts the process all over again.
1,918件の閲覧回数
yvesb
thank you for your answer!
we have a problem, when the microcontroller has never been flashed, if the external watchdog timer is connected, we don't manage to flash it (using JTAG)
