Memory allocation using malloc/calloc problem in USB Stack
vikashkumar
I'm working on USB host integration. In usb_khci_preinit() function i'm trying to allocate memory at run time using malloc.
I tried with  OS_Mem_alloc_zero(sizeof(usb_khci_host_state_struct_t)); function as well as int *p=malloc(10);.
In both cases i got return value is 0. It means i unable to allocate memory.
I need some help to solve this problem.
bobpaddock
Senior Contributor IV
Check that the linker script allocates any heap memory.
Also see this discussion:
https://community.nxp.com/thread/441637
