MbedTLS, http header
2,391件の閲覧回数
a8Chcx
Contributor V
I am using FRDM-K66 to test my HTTPS client, and it looks fine because I can negotiate with server.
When I send the following http request, always get "invalid token":
#define GET_REQUEST \
 "GET https://192.168.100.1:9882/snore/termmgmt/install/gps HTTP/1.1\r\n" \
 "X_Auth_Token:secureSnoreToken\r\n HOST: 192.168.100.1\r\n\r\n"
But it works when I am using the following curl command:
curl -i -k -H "X_Auth_Token:secureSnoreToken" https://192.168.100.1:9882/snore/termmgmt/install/gps
Can anybody tell me how to set up GET request for token in http header?
Christie
3 返答(返信)
2,332件の閲覧回数
Pavel_Hernandez
Could you share a Wireshark sniffer with us? I want to check the HTTP header.
I recommend using a sprintf() or string instead of the #define.
Pavel
2,326件の閲覧回数
a8Chcx
Contributor V
Hi Paul,
In Wireshark, all data are encoded and looks like useless...
Do you have any way to see encoded data?
Christie
2,297件の閲覧回数
Pavel_Hernandez
Does this issue persist if you use it without encryption?
Could you have a version of your code you can share with us? This is easier to have the same environment, I have one k66 for replay this case.
Pavel
