Mbed Compiler Error - "Error: No linker script found"
3,969 次查看
shobitsharma01
I tried compiling a code for FRDM-KL25Z board to flash different colors on RGB LED but ran into an error - "Error: No linker script found". The code (Main.cpp) and header file(MKL25Z.h) is attached with this question. I am using online Mbed IDE (ide.mbed.com) to compile and create a .bin file for board.
3,643 次查看
Sabina_Bruce
Hello Shobit,
For error messages regarding the compiler, you will need to contact MBED directly.
Here is their support page where you can redirect your question.
Sabina
