Maximum NAND Flash memory capacity supported by MK70FN1M0VMJ12
2,462 次查看
puspamnayak
I want to know what is the maximum memory capacity of NAND Flash will be supported by MK70FN1M0VMJ12
Request you to reply ASAP
Thanks and regards,
Puspam N
标记 (1)
4 回复数
2,120 次查看
Hui_Ma
NAND Flash is different with NOR Flash, Kineits NAND Flash controller Supports all NAND flash products regardless of density/organization. There with no memory size limited with NAND Flash.
Wish it helps.
best regards
Ma Hui
2,120 次查看
puspamnayak
Hi Hui,
Thanks for your reply.
I am planning to use 1 Tb NAND Flash.
So as per your explaination NAND Flash controller of K70 will able to address 1 Tb NAND Flash ?
Kindly reply
Thanks and regards,
Puspam Nayak
2,120 次查看
Hui_Ma
Yes, the K70 NAND Flash controller is able to address 1Tb NAND Flash.
It also need the file system to support that  amount size NAND Flash.
Wish it helps.
best regards
Ma Hui
2,120 次查看
puspamnayak
Thanks Hui for the clarification
Puspam N
