Mapping window builder generated resources to kinetis frdmk22f board +TWR LCD
763 次查看
sailajav
Please help!
I have designed a simple text box screen in window builder in PEG PRO Lite and generated resources abc.cpp, abc.hpp
Could you please share how to map this code to frdmK22 board + TWR LCD.
Guide us where to get source code of real LCD h/w mapping in frdmK22,
How to map this h/w with window build generated resource files to simulate on LCD.
Sai
标记 (3)
689 次查看
Hui_Ma
The FRDM and Tower evaluation boards design idea is different.
FRDM board is designed for Arduino compatibility.
Why customer doesn't consider to select use a Arduino LCD board, such as 3.2 inch LCD TF Card Shield.
If customer want to use TWR-LCD, it need to select TWR-K22F120M board.
There is an application note AN4644 about eGUI library application at TWR-K60N512 board with TWR-LCD board with MQX RTOS.
Related application source could be downloaded from here AN4644SW.
About Arduino LCD board application, I attached a project for your reference, which using SPI interface with LCD Controller with eGUI library at MQX RTOS.
Wish it helps.
Mike
