MKS22FN vs MK22FN flash programme
chris_f
Contributor V
I'm trying to use openocd to programme an MKS22FN256VLL12. Openocd doesn't yet support the MKS parts but does support the MK22FN parts.
How different is an MKS22FN256 to a MK22FN256 from a flash programming perspective?
I've tried patching openocd to treat the MKS22 part as if it is an MK22 but am getting flash erase and memory write errors though this is a new PCB so may have other problems.
Hui_Ma
I don't find there with Flash programming difference between MKS22FN256 vs.MK22FN256.
You can porting Flash program algorithm for MK22FN256 to MKS22FN256 .
The only difference of Flash command is that:
MKS22FN256 has Erase All Blocks Unsecure command (0x49),
MK22FN256 doesn't has this Flash command.
Wish it  helps.
Mike
Hui_Ma
Wish it  helps.
Mike
chris_f
Contributor V
Thanks for the confirmation Mike.
