MKM34 Uart DMA Initialization
2,487 次查看
rahul_4
Can anyone share the example of using DMA on UART Transmit for MKM34Z256 by using bare metal drivers. DMA CRC example is given but when I am changing the code for UART, it is not transmitting any data.
Rahul
2,434 次查看
rahul_4
Hi Rong,
I am using DMA for Uart Transmit but MCU is not transferring any data. Can you please check below code snippet.
Rahul
2,441 次查看
xiangjun_rong
I suppose that the DMA code has issue.
Pls refer to the DMA memory-memory example code and modify it, for example, replace the destination address with the CRC data register address. while check the CRC example code especially the CRC init code.
Hope it can help you
XiangJun Rong
