MKL24Z32VFM4 exposed pad?
已解决
跳至解决方案
2,040 次查看
larryklotz
MKL24Z32VFM4 is in an unusual package SOT617-17.  There's not much info on what electrically, if anything, it should attach to.  Package doc calls it "EXPOSED DIE ATTACH PAD".  Should it be attached to VSS/VSSA?
1 解答
1,939 次查看
Robin_Shen
Hi LARRY,
The bottom of the package provides the primary heat removal path, as well as excellent electrical grounding to the PCB through an exposed pad (EP).
Please check the application note AN1902 for more information.
Robin
在原帖中查看解决方案
2 回复数
1,940 次查看
Robin_Shen
Hi LARRY,
Robin
1,940 次查看
larryklotz
Thanks Robin.  This statement in Sec. 4.2.2 is the only place anywhere that states connecting the pad to circuit ground.
LK
