MKL24Z32VFM4 exposed pad?
1,993件の閲覧回数
larryklotz
MKL24Z32VFM4 is in an unusual package SOT617-17.  There's not much info on what electrically, if anything, it should attach to.  Package doc calls it "EXPOSED DIE ATTACH PAD".  Should it be attached to VSS/VSSA?
1,892件の閲覧回数
Robin_Shen
Hi LARRY,
The bottom of the package provides the primary heat removal path, as well as excellent electrical grounding to the PCB through an exposed pad (EP).
Please check the application note AN1902 for more information.
Robin
1,893件の閲覧回数
Robin_Shen
Hi LARRY,
Robin
1,893件の閲覧回数
larryklotz
Thanks Robin.  This statement in Sec. 4.2.2 is the only place anywhere that states connecting the pad to circuit ground.
LK
