MKL17 VREFH
MKL17 VREFH
3,323 次查看
publius1
I'm planning on using a MKL17 64 pin device for a new design.
I want to connect VREFH to an external accurate reference (over temperature).
I cannot seem to find the minimal and maximal VREFH voltages with respect to Vdda in the datasheet.
Does anybody know where the VREFH/VREFL minimal and maximal operating conditions are specified?
Koen
3,186 次查看
crystinstoll
4 回复数
3,186 次查看
miduo
Sorry we do not have the data regarding the minimal and maximal VREFH voltages with respect to Vdda. Only we provide is the the VREFH min 1.13V and max VDDA. The ADC will have correct value when working within this range.
3,186 次查看
publius1
Hi Fang,
Thanks for your response.
Where did you get these values from? Could you provide the document ID?
Koen
3,187 次查看
crystinstoll
3,186 次查看
publius1
Hi Crystin,
Thanks.
Since I was planning on using the 32kb device I looked in that datasheet, there is no mention of the Vrefh range in that version though.
