MKL02Z32VFM4 dump/reflash entire chip
1,484 次查看
moash
iv been creating my own custom pcb that requires this chip but the ones i seem to have bought are blank/ have no bootloader on them.
My question is, is it possible to dump the bootloader from a known working chip and then mass flash onto my blanks.
If so could i get documentation/ step by step on the process.
thanks in advance
2 回复数
1,462 次查看
xiangjun_rong
This is the website of MCU-Boot:
https://www.nxp.com/design/design-center/software/development-software/mcuxpresso-software-and-tools...
From the list, you can see that the KL02 does not have ROM flashloader, but KL03 has the ROM flashloader. Pls check if you replace with KL03 if you require ROM flashloader.
BTW, there is Kinetis MCU programming service, pls go to the website:
Hope it can help you
Xiangjun Rong
1,443 次查看
moash
https://www.pjrc.com/store/ic_mkl02_t4.html
the top chip is the one i was supposed to get i suppose, i assume there is no way for me to rip what i need off of this to then mass flash on to my own ?
thanks again for the reply
