MK60DN256VLQ10 Issue while programming
rameshmathpati
We are using MK60DN256VLQ10 controller in one of the project
These are the observations we found while programming
1.An error occurred while connecting to the interface hardware/PE micro GDB launch failure
2.Controller unsecured (in few controller)
This problem we faced in almost 50 controllers out of 100
We want to know the actual cause for the issue
Kindly give us the solution for the same
ramesh_mathpati
We are using NXP MK60DN256VLQ10 Controller in one the project we are facing problem in many boards while programming.
IDE:Kinetics Design studio (Freescale) version .
Kindly give us the some solution for this problem as we had communicated with NXP support team last year regarding same issue but we have not got any solution.
Only 50% of the controller are getting programmed.
We want somebody from NXP should come to our office and look into the problem.
Please send me your mail ID so i can forward schematic and related documents.
Hui_Ma
Sorry for the later reply.
If you need on site support, please contact with your local NXP distributor.
If possible, could you share your MK60DN256VLQ10  MCU related debugger circuit here?
We could double check that schematics.
And if customer try use another programmer software, such as P&E PROGACMP software.
Thank you for the attention.
Mike
Hui_Ma
Could you please provide the MK60DN256VLQ10  JTAG/SWD related debugger circuit?
And could you provide the KDS software version? Thanks.
Ma Hui
