I want to get certainly all results of an ADC on MK60 which is working in Continuous Conversion mode (SC3 ADCO=1).
I have two questions relating to this:
1. Is there a register flag (or a other possibility) to detect when a new ADC result overwrites an old result before it was read?
2. Which DMA registers have to be set (with which values) to use a DMA for transferring the ADC2 results to a memory address and get a DMA interrupt after 200 ADC samples?
I have checked some application notes already but the DMA usage seemed always very complex.
So I would be glad if you could specify the DMA register contents which are essential to be set.
Thanks a lot for your help.
Hape
