MK20DX128VFM5 IAR EWARM Source Code
1,907 次查看
fezaifethi
we want to use the MK20DX128VFM5  for our project , the probleme is I'm a little bit confused, I can't found the source code (library + example for this component)
I want to know, If I can use the TWR-K20D50M 's Firmware?
Or should we, change the chip?
Fezai
1,806 次查看
miduo
Yes, you can use TWR-K20D50M as an evaluation board. You can download the sample code for the board from the link below:
http://www.nxp.com/assets/downloads/data/en/board-support-packages/TWR-K20D50M_LABS_AND_CE.zip
1,806 次查看
fezaifethi
Hi Fang Li,
Thank you for your fast reply.
