MK20 (Kinetis K-Series) program section fails although program longword works fine
1,021件の閲覧回数
phillipschuster
after a very long time getting that to work I hope to find an answer here. I want to program a MK20DX256VLH7 via SWD. Programming the MCU on my custom PCB using a J-LINK Segger works fine.
My custom PCB also hosts an ESP8266 that I want to use to create over the air updates of the MK20DX firmware. I managed to write a firmware for ESP8266 that programs the MK20 with the longword programming style. This actually works and works quite reliable, but it's insanely slow. It takes minutes.
So I want to use program section programming. But this just does not work. Here is a high level dump of my debug log. I am quite sure that my low level SWD functions are working fine as they are used with longword programming, too.
As I choose 0 as the starting address for longword programming and when using the J-Link I think it makes sense to use in section programming, too. However, I found that (https://freescale.jiveon.com/thread/307491 ) which has 0x80 as starting address. I am not sure if this makes any sense. Trying that also fails.
Any idea what I could make wrong? Of course I can provide more source code, but perhaps my issue is more on the high level (start address, etc). FSTAT register always has this value 0xfffe02a0. Perhaps anyone has an idea what's wrong here?
Thanks very much!
Phillip
Downloaded file
Reseting MK20 - the hard way
Resetting MK20 done
Flashing MK20
Found ARM processor debug port (IDCODE: 2ba01477)
Debug Port Powered Up
Debug Port Detected: 2BA01477
Device reset complete
Debug halt complete
K20 initialized
Done
Initialize flash process
Begin Flashing
FLASH: flashSectorErase
Sector 00000000 erased
FLASH: Wrote longword at 00000000, 0: 20, 1: 00, 2: 80, 3: 00, Word: 00800020
FLASH: Wrote longword at 00000001, 0: 00, 1: 00, 2: 01, 3: bd, Word: bd010000
FLASH: Wrote longword at 00000002, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000003, 0: 00, 1: 00, 2: 14, 3: a1, Word: a1140000
FLASH: Wrote longword at 00000004, 0: 00, 1: 00, 2: 14, 3: a1, Word: a1140000
FLASH: Wrote longword at 00000005, 0: 00, 1: 00, 2: 14, 3: a1, Word: a1140000
FLASH: Wrote longword at 00000006, 0: 00, 1: 00, 2: 14, 3: a1, Word: a1140000
FLASH: Wrote longword at 00000007, 0: 00, 1: 00, 2: 14, 3: a1, Word: a1140000
FLASH: Wrote longword at 00000008, 0: 00, 1: 00, 2: 14, 3: a1, Word: a1140000
FLASH: Wrote longword at 00000009, 0: 00, 1: 00, 2: 14, 3: a1, Word: a1140000
FLASH: Wrote longword at 0000000a, 0: 00, 1: 00, 2: 14, 3: a1, Word: a1140000
FLASH: Wrote longword at 0000000b, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000000c, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000000d, 0: 00, 1: 00, 2: 14, 3: a1, Word: a1140000
FLASH: Wrote longword at 0000000e, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000000f, 0: 00, 1: 00, 2: 14, 3: 91, Word: 91140000
FLASH: Wrote longword at 00000010, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000011, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000012, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000013, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000014, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000015, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000016, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000017, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000018, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000019, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000001a, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000001b, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000001c, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000001d, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000001e, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000001f, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000020, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000021, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000022, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000023, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000024, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000025, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000026, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000027, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000028, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000029, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000002a, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000002b, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000002c, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000002d, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000002e, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000002f, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000030, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000031, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000032, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000033, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000034, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000035, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000036, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000037, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000038, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000039, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000003a, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000003b, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000003c, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000003d, 0: 00, 1: 00, 2: 1b, 3: 1d, Word: 1d1b0000
FLASH: Wrote longword at 0000003e, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000003f, 0: 00, 1: 00, 2: 22, 3: 15, Word: 15220000
FLASH: Wrote longword at 00000040, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000041, 0: 00, 1: 00, 2: 27, 3: 3d, Word: 3d270000
FLASH: Wrote longword at 00000042, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000043, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000044, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000045, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000046, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000047, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000048, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000049, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000004a, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000004b, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000004c, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000004d, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000004e, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000004f, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000050, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000051, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000052, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000053, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000054, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000055, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000056, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000057, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000058, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000059, 0: 00, 1: 00, 2: 08, 3: 99, Word: 99080000
FLASH: Wrote longword at 0000005a, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000005b, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000005c, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000005d, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000005e, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000005f, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000060, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000061, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000062, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000063, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000064, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000065, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000066, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000067, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000068, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 00000069, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000006a, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000006b, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000006c, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000006d, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000006e, 0: 00, 1: 00, 2: 14, 3: dd, Word: dd140000
FLASH: Wrote longword at 0000006f, 0: f2, 1: 4c, 2: 4b, 3: 57, Word: 574b4cf2
FLASH: Wrote longword at 00000070, 0: b5, 1: 10, 2: 52, 3: 20, Word: 205210b5
FLASH: Wrote longword at 00000071, 0: f6, 1: 4d, 2: 80, 3: 1a, Word: 1a804df6
FLASH: Wrote longword at 00000072, 0: 80, 1: 1a, 2: 12, 3: 28, Word: 28121a80
FLASH: Wrote longword at 00000073, 0: bf, 1: 00, 2: bf, 3: 00, Word: 00bf00bf
FLASH: Wrote longword at 00000074, 0: f9, 1: 88, 2: f0, 3: 01, Word: 01f088f9
FLASH: Wrote longword at 00000075, 0: f0, 1: 4f, 2: 4b, 3: 52, Word: 524b4ff0
FLASH: Wrote longword at 00000076, 0: 60, 1: 1a, 2: 62, 3: 10, Word: 10621a60
FLASH: Wrote longword at 00000077, 0: 60, 1: 9a, 2: 4a, 3: 51, Word: 514a9a60
FLASH: Wrote longword at 00000078, 0: 60, 1: da, 2: 4a, 3: 51, Word: 514ada60
FLASH: Wrote longword at 00000079, 0: 43, 1: 30, 2: f5, 3: a3, Word: a3f53043
FLASH: Wrote longword at 0000007a, 0: 68, 1: 1a, 2: 3b, 3: 20, Word: 203b1a68
FLASH: Wrote longword at 0000007b, 0: 72, 1: 80, 2: f4, 3: 12, Word: 12f48072
FLASH: Wrote longword at 0000007c, 0: 49, 1: 4e, 2: d1, 3: 04, Word: 04d14e49
FLASH: Wrote longword at 0000007d, 0: f4, 1: 4f, 2: 60, 3: 0a, Word: 0a604ff4
FLASH: Wrote longword at 0000007e, 0: 60, 1: 1a, 2: 52, 3: a8, Word: a8521a60
FLASH: Wrote longword at 0000007f, 0: 78, 1: 1a, 2: 4b, 3: 4c, Word: 4c4b1a78
FLASH: Wrote longword at 00000080, 0: d5, 1: 03, 2: 07, 3: 11, Word: 110703d5
FLASH: Wrote longword at 00000081, 0: f0, 1: 42, 2: 78, 3: 1a, Word: 1a7842f0
FLASH: Wrote longword at 00000082, 0: 70, 1: 1a, 2: 02, 3: 08, Word: 08021a70
FLASH: Wrote longword at 00000083, 0: 4c, 1: 4a, 2: 4b, 3: 49, Word: 494b4a4c
FLASH: Wrote longword at 00000084, 0: 22, 1: 2a, 2: 48, 3: 4a, Word: 4a482a22
FLASH: Wrote longword at 00000085, 0: 4a, 1: 4a, 2: 70, 3: 1a, Word: 1a704a4a
FLASH: Wrote longword at 00000086, 0: 18, 1: 99, 2: 23, 3: 00, Word: 00239918
FLASH: Wrote longword at 00000087, 0: d2, 1: 03, 2: 42, 3: a1, Word: a14203d2
FLASH: Wrote longword at 00000088, 0: 50, 1: 99, 2: 58, 3: 19, Word: 19589950
FLASH: Wrote longword at 00000089, 0: e7, 1: f8, 2: 33, 3: 04, Word: 0433f8e7
FLASH: Wrote longword at 0000008a, 0: 49, 1: 47, 2: 4b, 3: 46, Word: 464b4749
FLASH: Wrote longword at 0000008b, 0: 42, 1: 8b, 2: 22, 3: 00, Word: 00228b42
FLASH: Wrote longword at 0000008c, 0: f8, 1: 43, 2: d2, 3: 02, Word: 02d243f8
FLASH: Wrote longword at 0000008d, 0: e7, 1: fa, 2: 2b, 3: 04, Word: 042bfae7
FLASH: Wrote longword at 0000008e, 0: 49, 1: 45, 2: 48, 3: 44, Word: 44484549
FLASH: Wrote longword at 0000008f, 0: 58, 1: 5a, 2: 23, 3: 00, Word: 00235a58
FLASH: Wrote longword at 00000090, 0: 33, 1: 04, 2: 50, 3: 1a, Word: 1a500433
FLASH: Wrote longword at 00000091, 0: 7f, 1: de, 2: f5, 3: b3, Word: b3f5de7f
FLASH: Wrote longword at 00000092, 0: 4b, 1: 42, 2: d1, 3: f9, Word: f9d1424b
FLASH: Wrote longword at 00000093, 0: 21, 1: 80, 2: 4a, 3: 42, Word: 424a8021
FLASH: Wrote longword at 00000094, 0: 1b, 1: 01, 2: f8, 3: 03, Word: 03f8011b
FLASH: Wrote longword at 00000095, 0: d1, 1: fb, 2: 42, 3: 93, Word: 9342fbd1
FLASH: Wrote longword at 00000096, 0: 4a, 1: 3c, 2: 4b, 3: 40, Word: 404b3c4a
FLASH: Wrote longword at 00000097, 0: 4b, 1: 40, 2: 60, 3: 1a, Word: 1a60404b
FLASH: Wrote longword at 00000098, 0: 70, 1: 1a, 2: 22, 3: 0a, Word: 0a221a70
FLASH: Wrote longword at 00000099, 0: 53, 1: 80, 2: f5, 3: a3, Word: a3f58053
FLASH: Wrote longword at 0000009a, 0: 70, 1: 5a, 2: 22, 3: 24, Word: 24225a70
FLASH: Wrote longword at 0000009b, 0: 70, 1: 1a, 2: 22, 3: a0, Word: a0221a70
FLASH: Wrote longword at 0000009c, 0: 07, 1: 92, 2: 79, 3: 9a, Word: 9a799207
FLASH: Wrote longword at 0000009d, 0: 79, 1: 9a, 2: d5, 3: fc, Word: fcd59a79
FLASH: Wrote longword at 0000009e, 0: d4, 1: fc, 2: 06, 3: d4, Word: d406fcd4
FLASH: Wrote longword at 0000009f, 0: 79, 1: 93, 2: 4a, 3: 39, Word: 394a9379
FLASH: Wrote longword at 000000a0, 0: 03, 1: 0c, 2: f0, 3: 03, Word: 03f00c03
FLASH: Wrote longword at 000000a1, 0: 4b, 1: 37, 2: 2b, 3: 08, Word: 082b374b
FLASH: Wrote longword at 000000a2, 0: 22, 1: 03, 2: d1, 3: f9, Word: f9d10322
FLASH: Wrote longword at 000000a3, 0: 22, 1: 40, 2: 71, 3: 1a, Word: 1a714022
FLASH: Wrote longword at 000000a4, 0: 79, 1: 9a, 2: 71, 3: 5a, Word: 5a719a79
FLASH: Wrote longword at 000000a5, 0: d5, 1: fc, 2: 06, 3: 90, Word: 9006fcd5
FLASH: Wrote longword at 000000a6, 0: 79, 1: 91, 2: 4a, 3: 32, Word: 324a9179
FLASH: Wrote longword at 000000a7, 0: 06, 1: 49, 2: 4b, 3: 31, Word: 314b4906
FLASH: Wrote longword at 000000a8, 0: 4a, 1: 31, 2: d5, 3: fb, Word: fbd5314a
FLASH: Wrote longword at 000000a9, 0: 60, 1: 11, 2: 49, 3: 31, Word: 31491160
FLASH: Wrote longword at 000000aa, 0: 60, 1: 51, 2: 21, 3: 02, Word: 02215160
FLASH: Wrote longword at 000000ab, 0: 70, 1: 1a, 2: 22, 3: 20, Word: 20221a70
FLASH: Wrote longword at 000000ac, 0: f0, 1: 02, 2: 79, 3: 9a, Word: 9a7902f0
FLASH: Wrote longword at 000000ad, 0: 2a, 1: 0c, 2: 02, 3: 0c, Word: 0c020c2a
FLASH: Wrote longword at 000000ae, 0: 4b, 1: 2d, 2: d1, 3: fa, Word: fad12d4b
FLASH: Wrote longword at 000000af, 0: 60, 1: 1a, 2: 4a, 3: 2d, Word: 2d4a1a60
FLASH: Wrote longword at 000000b0, 0: 4a, 1: 2e, 2: 4b, 3: 2d, Word: 2d4b2e4a
FLASH: Wrote longword at 000000b1, 0: 22, 1: 00, 2: 60, 3: 1a, Word: 1a600022
FLASH: Wrote longword at 000000b2, 0: 22, 1: 07, 2: 60, 3: 5a, Word: 5a600722
FLASH: Wrote longword at 000000b3, 0: 2c, 1: 04, 2: f8, 3: 43, Word: 43f8042c
FLASH: Wrote longword at 000000b4, 0: f8, 1: c3, 2: 4a, 3: 2b, Word: 2b4ac3f8
FLASH: Wrote longword at 000000b5, 0: b6, 1: 62, 2: 2d, 3: 0c, Word: 0c2d62b6
FLASH: Wrote longword at 000000b6, 0: f9, 1: a0, 2: f0, 3: 00, Word: 00f0a0f9
FLASH: Wrote longword at 000000b7, 0: 68, 1: 1b, 2: 4b, 3: 13, Word: 134b1b68
FLASH: Wrote longword at 000000b8, 0: d5, 1: 05, 2: 07, 3: da, Word: da0705d5
FLASH: Wrote longword at 000000b9, 0: f0, 1: 00, 2: 48, 3: 27, Word: 274800f0
FLASH: Wrote longword at 000000ba, 0: 4b, 1: 27, 2: f8, 3: dd, Word: ddf8274b
FLASH: Wrote longword at 000000bb, 0: 60, 1: 1a, 2: 4a, 3: 27, Word: 274a1a60
FLASH: Wrote longword at 000000bc, 0: 78, 1: 1b, 2: 4b, 3: 27, Word: 274b1b78
FLASH: Wrote longword at 000000bd, 0: d5, 1: 09, 2: 06, 3: 5b, Word: 5b0609d5
FLASH: Wrote longword at 000000be, 0: 4a, 1: 24, 2: 4c, 3: 23, Word: 234c244a
FLASH: Wrote longword at 000000bf, 0: 42, 1: 93, 2: 68, 3: 23, Word: 23689342
FLASH: Wrote longword at 000000c0, 0: 48, 1: 20, 2: d1, 3: 04, Word: 04d12048
FLASH: Wrote longword at 000000c1, 0: f8, 1: ce, 2: f0, 3: 00, Word: 00f0cef8
FLASH: Wrote longword at 000000c2, 0: 60, 1: 23, 2: 23, 3: 00, Word: 00232360
FLASH: Wrote longword at 000000c3, 0: fd, 1: 02, 2: f0, 3: 02, Word: 02f002fd
FLASH: Wrote longword at 000000c4, 0: f8, 1: ee, 2: f0, 3: 01, Word: 01f0eef8
FLASH: Wrote longword at 000000c5, 0: f8, 1: 08, 2: f0, 3: 01, Word: 01f008f8
FLASH: Wrote longword at 000000c6, 0: bf, 1: 00, 2: e7, 3: fe, Word: fee700bf
FLASH: Wrote longword at 000000c7, 0: 40, 1: 05, 2: 20, 3: 0e, Word: 0e200540
FLASH: Wrote longword at 000000c8, 0: 40, 1: 04, 2: 80, 3: 30, Word: 30800440
FLASH: Wrote longword at 000000c9, 0: 00, 1: 04, 2: 3f, 3: 82, Word: 823f0400
FLASH: Wrote longword at 000000ca, 0: 2b, 1: 00, 2: 00, 3: 01, Word: 0100002b
FLASH: Wrote longword at 000000cb, 0: 40, 1: 03, 2: d0, 3: 14, Word: 14d00340
FLASH: Wrote longword at 000000cc, 0: 40, 1: 07, 2: d0, 3: 02, Word: 02d00740
FLASH: Wrote longword at 000000cd, 0: 40, 1: 07, 2: e0, 3: 00, Word: 00e00740
FLASH: Wrote longword at 000000ce, 0: 1f, 1: ff, 2: 8c, 3: 40, Word: 408cff1f
FLASH: Wrote longword at 000000cf, 0: 00, 1: 00, 2: 31, 3: 98, Word: 98310000
FLASH: Wrote longword at 000000d0, 0: 1f, 1: ff, 2: 87, 3: 60, Word: 6087ff1f
FLASH: Wrote longword at 000000d1, 0: 1f, 1: ff, 2: 8c, 3: 40, Word: 408cff1f
FLASH: Wrote longword at 000000d2, 0: 1f, 1: ff, 2: 8f, 3: 38, Word: 388fff1f
FLASH: Wrote longword at 000000d3, 0: 1f, 1: ff, 2: 82, 3: 00, Word: 0082ff1f
FLASH: Wrote longword at 000000d4, 0: 00, 1: 00, 2: 00, 3: 00, Word: 00000000
FLASH: Wrote longword at 000000d5, 0: e0, 1: 00, 2: e4, 3: 00, Word: 00e400e0
FLASH: Wrote longword at 000000d6, 0: e0, 1: 00, 2: e4, 3: 5f, Word: 5fe400e0
FLASH: Wrote longword at 000000d7, 0: e0, 1: 00, 2: ed, 3: 08, Word: 08ed00e0
FLASH: Wrote longword at 000000d8, 0: 40, 1: 06, 2: 50, 3: 00, Word: 00500640
FLASH: Wrote longword at 000000d9, 0: 40, 1: 06, 2: 40, 3: 00, Word: 00400640
FLASH: Wrote longword at 000000da, 0: 40, 1: 04, 2: 80, 3: 44, Word: 44800440
FLASH: Wrote longword at 000000db, 0: 01, 1: 03, 2: 00, 3: 00, Word: 00000301
FLASH: Wrote longword at 000000dc, 0: 40, 1: 04, 2: 80, 3: 04, Word: 04800440
FLASH: Wrote longword at 000000dd, 0: 00, 1: 05, 2: 10, 3: c0, Word: c0100500
FLASH: Wrote longword at 000000de, 0: e0, 1: 00, 2: e0, 3: 14, Word: 14e000e0
FLASH: Wrote longword at 000000df, 0: 00, 1: 01, 2: 76, 3: ff, Word: ff760100
FLASH: Wrote longword at 000000e0, 0: 20, 1: 20, 2: 00, 3: 00, Word: 00002020
FLASH: Wrote longword at 000000e1, 0: 57, 1: 67, 2: cc, 3: 3b, Word: 3bcc6757
FLASH: Wrote longword at 000000e2, 0: 40, 1: 03, 2: e0, 3: 1c, Word: 1ce00340
FLASH: Wrote longword at 000000e3, 0: 5a, 1: 94, 2: c3, 3: a5, Word: a5c3945a
FLASH: Wrote longword at 000000e4, 0: 40, 1: 07, 2: f0, 3: 00, Word: 00f00740
FLASH: Wrote longword at 000000e5, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000e6, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000e7, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000e8, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000e9, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000ea, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000eb, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000ec, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000ed, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000ee, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000ef, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000f0, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000f1, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000f2, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000f3, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000f4, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000f5, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000f6, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000f7, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000f8, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000f9, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000fa, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000fb, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000fc, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000fd, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000fe, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: Wrote longword at 000000ff, 0: ff, 1: ff, 2: ff, 3: ff, Word: ffffffff
FLASH: flashSectorProgram: 00000000
Programming section at 00000000, numWords: 00000100
FLASH: Address access error (FSTAT: fffe02a0)
FLASH: flashSectorProgram failed
End flashing
Resetting Chip
Flashing MK20 complete
タグ(2)
0 返答(返信)
