MK10DN512VLK10 no eeprom ,how to Storage parameters
1,866 次查看
李志權
MK10DN512VLK10 no eeprom ,how to Storage parameters?
I use CodeWarrior 10.4 with PE
1,652 次查看
Hui_Ma
For the device without FlexMemory (eeprom), you could use  Flash command to erase/program a Flash sector to emulate eeprom operation.
You can refer C90TFS_FLASH_DRIVER: TFS Flash Driver Software for Kinetis and ColdFire+ Microcontrollers from below link, which provides Flash operation demo.
http://cache.freescale.com/files/32bit/software/C90TFS_FLASH_DRIVER.exe
Wish it help.
1,652 次查看
李志權
Thanks,I use FLASH_LDD to finsh Storage parameters function.
1,652 次查看
Hui_Ma
Please check attached project, which is using FLASH_LDD component of PE with CW V10.5 to write/read data from Flash memory address 0x40000.
Wish it helps.
