MED-EKG BOM
MED-EKG BOM
7,118 次查看
sooryakrishnanu
Hi ,
Anyone please help me to get med-EKG BOM?I could not find anywhere in NXP Website!
标记 (2)
6,793 次查看
Hui_Ma
Please check attached MED-EKG BOM file.
Wish it helps.
best regards,
Ma Hui
6 回复数
6,794 次查看
Hui_Ma
Wish it helps.
best regards,
Ma Hui
6,793 次查看
sooryakrishnanu
Thanks MA Hui,I already got the BOM ,but now the issues is with availability of some components.May i know which distributor provide these components?
6,793 次查看
Hui_Ma
Could you list which components you want to know the vendor?
best regards,
Ma Hui
6,793 次查看
sooryakrishnanu
Hi ,
                    Thanks Ma Hui, I have attached the missing components.Please find the attached.Thanks.
6,793 次查看
Hui_Ma
1> CAP TANT 10UF 16V 20% -- 3216-16  NTC-T106M16TRAF
Could be purchased at Avnet:  NIC Components NTC-T106M16TRAF, 3216-18,A, 10 uF, 16 Vdc, 20 % - Avnet Express
2> CAP CER 0.33UF 25V 10% X7R 0603
Could not found the same part number, while from Avnet could found the same package and electrical feature, please check below capacitor list below:
The following capacitor and resistor, customer also could found the similar product at Avnet web site:
Avnet Express - Electronic Components Distributor and Services
CAP CER 0.022UF 25V 5% C0G 0805
CAP CER 2.2UF 10V 5% X7R 0603
RES MF 330 OHM 1/10W 5% 0603
RES MF 2.2K 1/32W 0.1% 0603
RES MF 47K 1/16W 5% 0603
RES MF ZERO OHM 1/10W -- 0603
best regards,
Ma Hui
6,793 次查看
sooryakrishnanu
Thank you very much Ma Hui.I was really stuck when the part number was not given any ways thanks for your help.Will get back to you if i need some clarifications.Thanks.
