MCU bootloader size
MCU bootloader size
3,632 次查看
zorrotz
How much flash and RAM is required for the MCU bootloader?
Thanks in advance
3,626 次查看
ErichStyger
Specialist I
It really depends on the features you select and optimization level too.
See https://mcuoneclipse.com/2018/03/03/flash-resident-usb-hid-bootloader-with-the-nxp-kinetis-k22-micro... where it shows different configurations.
3,627 次查看
ErichStyger
Specialist I
3,611 次查看
zorrotz
Thank you very much.
I only wanted to have a general idea of required size.
By the way, I follow your blog and I find it very useful to learn MCUXpresso tricks.
3,607 次查看
ErichStyger
Specialist I
Thank you :-).
To give you an idea:
My bootloader (McuBoot) for the K22 supporting USB HID needs around 18KB Flash and 8 KB RAM (-Os)
Erich
