MCU_Grounding DDR pins
1,194 次查看
madhusharmak
I’m using an MCU with part number: MK61FN1M0VMJ12. Could you please let me know is it mandatory to ground all DDR_DQ lines if DDR interface is not used.
Thanking you
Madhu Sharma K
1,113 次查看
Hui_Ma
If the DDR interface is not used, the DDR_DQ lines could be left floating.
Wish it helps.
best regards,
Ma Hui
