MCG
MCG
1,652件の閲覧回数
nesrinemhiri
i use the Chip MK10FX512VLQ 12,i do a generic bord with this chip,when i debug my code,it enter into while 1 due to MCG configuration:
0x11 - IREFST did not clear within allowed time, FLL reference did not switch over from internal to external clock,
what kind of problem can generate this errors?
2 返答(返信)
1,549件の閲覧回数
Kan_Li
What is clock source for MK10FX512VLQ12? Would you please share your schematics for a review? Thanks for your patience!
Kan
1,549件の閲覧回数
nesrinemhiri
at the first i used the oscillator 0 with 50MHz but now i use clock input  with GBF so it's okey.
Thank you for your response KAN
Nesrine
