Lockup on Reset Pin in VLLS2
1,832件の閲覧回数
leifzars
When in VLLS2 and the reset pin is hit, the System Reset Status Register reads a Lockup. This is using a Kinetis MK24FN1M  (1N8B3J).
Previously using the MK20DN512 (5N22D) this did not happen, I would get a PIN reset code.
Anyone experience this, or know a work around?
タグ(1)
1,713件の閲覧回数
jingpan
Hi Leif,
I don't quite know what you mean 'lockup'. I made a test on my TWR-K24F120M. I download the example power_mode_switch by keil. In Project->option->debug->setting->Reset, I select 'reset pin'. Then I let the chip into VLLS2. Then I press the RESET button on KEIL. The SRS register will be 0x41.
Then in Project->option->debug->setting->Reset, I select 'Core and peripherals'. And do same operate as before, the SRS register read as 0x1.
So I didn't see any problem. Can you give more detail about your question?
Jing
1,713件の閲覧回数
leifzars
In manual 6.2.2.9 Lockup reset (LOCKUP).
I must have something miss configured with my setup. Would you think the issue is on boot?
Any thoughts?
