LPUART interrupt problem in KW40Z Connectivity software version 1.0.1
1,277 次查看
vanajagujjala
I am using KW40Z_Connectivity_Software_1.0.1 and am trying to modify heart_rate_sensor code,
1. In heart_rate_sensor code I enabled  dbg_uart_init() function (by default it is disabled) to initialize lpuart.
2. In heart_rate_sensor code I enabled  DbgConsole_Init(BOARD_DEBUG_UART_INSTANCE, BOARD_DEBUG_UART_BAUD, kDebugConsoleLPUART) function (by default it is disabled).
3. Please find below steps to enable interrupt for LPUART
       LPUART0_CTRL |= LPUART_CTRL_RIE_MASK
       NVIC_EnableIRQ(LPUART_IRQn);
 LPUART Interrupt is not working, am I doing any thing wrong please suggest
Vanaja.
1,151 次查看
jorge_a_vazquez
Hi vanaja gujjala
Connectivity software for KW40Z uses its own Serial communication, you cannot use the debug_console one, because this doesn't consider the radio. I recommend you to check "3.9. Serial manager" of the connectivity framework Reference Manual. you can find the document in the path {KW40Z_Connectivity_Software_1.0.1_path}\ConnSw\doc\CONNFWKRM.pdf
Hope this information could help you.
Best Regards
Jorge Alcala
