Kinetis RTC clock sourced from IRC
Hi team :
     I would like to share an experience to you . Any comments would be welcome .
     The RTC 32.7668KHz clock can only be sourced from an external crystal that is challenged of some space restricted case . The internal reference clock will be required to support RTC at this moment . Of cause , the IRC accuracy maybe not compete with external crystal , but in this case space is the major concern . However , Kinetis RTC not support clock sourced from IRC . We make a workaround to enable RTC reference to IRC . The detail please refer to attachment . The sample code is build with KDS V3.0 for FRDM-K64F .
David
%3CLINGO-SUB%20id%3D%22lingo-sub-1126539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKinetis%20RTC%20clock%20sourced%20from%20IRC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EHi%20team%20%3A%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20I%20would%20like%20to%20share%20an%20experience%20to%20you%20.%20Any%20comments%20would%20be%20welcome%20.%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20The%20RTC%2032.7668KHz%20clock%20can%20only%20be%20sourced%20from%20an%20external%20crystal%20that%20is%20challenged%20of%20some%20space%20restricted%20case%20.%20The%20internal%20reference%20clock%20will%20be%20required%20to%20support%20RTC%20at%20this%20moment%20.%20Of%20cause%20%2C%20the%20IRC%20accuracy%20maybe%20not%20compete%20with%20external%20crystal%20%2C%20but%20in%20this%20case%20space%20is%20the%20major%20concern%20.%20However%20%2C%20Kinetis%20RTC%20not%20support%20clock%20sourced%20from%20IRC%20.%20We%20make%20a%20workaround%20to%20enable%20RTC%20reference%20to%20IRC%20.%20The%20detail%20please%20refer%20to%20attachment%20.%20The%20sample%20code%20is%20build%20with%20KDS%20V3.0%20for%20FRDM-K64F%20.%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EBest%20regards%2C%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎07-03-2015 04:01 AM
Updated by:
