Kinetis L25 USB host multiple mass storage devices
1,810 次查看
thomasost
Hi I want to connect several mass storage devices to a kinetis L microcontroller through an USB hub. Is this possible?
Micrcontroller USB Host---->USB HUB---->Several USB Mass Storage Devices
Tom
标记 (3)
1,633 次查看
kerryzhou
Hi Thomas Ost,
     Yes, you can connect Several USB MSD device to the USB HUB, then connect to the KL USB host.
Wish it helps you!
If you still have question, please contact with me!
Jingjing
1,634 次查看
kerryzhou
Hi Thomas Ost,
Wish it helps you!
Jingjing
