Kinetis KL26Z I2S Demo
2,060 次查看
danyonchu
I am using the FRDM-KL26Z dev board and using KSDK v1.3
I am trying to configure the board for use with I2S. Is there an exmple/demo sitting out there that can help point me in the right direction to get started setting up the CLKs and other things related?
1,924 次查看
Hui_Ma
KL43 is using the same I2S/SAI module with KL26 chip. Please check MCUXpresso SDK V2.2 for FRDM-KL26Z software package provides the SAI module driver (fsl_sai.c & fsl_sai.h) with below path:
..\SDK_2.2_FRDM-KL26Z\devices\MKL26Z4\drivers
The SAI demo software could be found at MCUXpresso SDK V2.2 for TWR-KL43Z48M board:
\SDK_2.2.1_TWR-KL43Z48M\boards\twrkl43z48m\driver_examples\sai
MCUXpresso SDK software package could be downloaded from here.
Wish it helps.
Ma Hui
1,925 次查看
danyonchu
Are there any SAI examples in SDK v1.3? I am trying to use the SAI drivers that are included in this version of the SDK. Found at "...\KSDK_1.3.0\platform\drivers\inc\fsl_sai_driver" I just assumed that if the drivers are included it, there should be prebuilt examples that came with it already.
1,925 次查看
Hui_Ma
Unfortunately, I don't find the SAI example at KSDK V1.3 software package. Sorry for that.
best regards,
Mike
