Kinetis K60 edge Rates
1,861 次查看
samsaprunoff
Good day All
Does anyone know the K60's edge rates (rise/fall times) for K60's Outputs? I cannot find this data in the K60 data sheets that I downloaded. I require this for my signal integrity calculations. In particular, I am interested in the cases of an output configured for fast and slow slew rates as well as high and normal drive strengths.
Thank you in advance!
Cheers,
Sam
标记 (3)
1,667 次查看
samsaprunoff
Good day All,
Freescale Tech support responded and suggested I look for this info in the processor's IBIS File.... I never thought of that!
Cheers,
Sam
1,668 次查看
samsaprunoff
Good day All,
Cheers,
Sam
