Kinetis K60 Flexbus FB_RW signal problem
2,468件の閲覧回数
monXii
i want to use the Flexbus for external RAM and Flash..
After some hours work and measuring with scope i found out that FB_RW always stay in last state ..
But my RAM and Flash wants that this signal goes after each read/write cycle back to high, cause they need this rising and falling edges on write cycles..
Any ideas? I don't found any settings like this ..
2,047件の閲覧回数
monXii
Found the problem!
I had a wrong idea ... FB_R/W signal is ok!
My BGA RAM was not soldered correctly ..
Sorry :smileyhappy:
2,048件の閲覧回数
monXii
Found the problem!
Sorry :smileyhappy:
