Kinetis Copy the code into RAM
1,938 次查看
cyesman
KV46 Two questions:
(1)I was testing the bootloader. How to copy the flash erase and program code into the RAM.(Keil IDE)
(2)How to copy the ISR into the RAM. Do you had a demo for this?(Keil IDE)
1,856 次查看
jingpan
Hi yu,
1, you can see here http://www.keil.com/support/docs/3723.htm
and here https://blog.csdn.net/lijianboyangting/article/details/78471045
2, you can copy the vector table to a certain address then write the start address to SCB->VTOR
Jing
