KW45 / MCXW71 Differences and Software Configurations
tomaru
Dear Team,
Thank youf or your support.
We are currently using your NXP KW45 series MCU for a BLE Specific application which does not require CAN.
I came across another MCU from NXP - MCX-W71.
As of what I can see there is not much difference apart from support of CAN Protocol.
Can you let me know if there are any other major differences ?
Regarding SW -
We have nearly developed your KW45 SW and would like to Migrate to MCXW71 willl it be possible ?
If we directly flash our SW, will it work ?
BR,
Tomaru
KW45B41Z-EVK KW45 MCX-W71X MCX-W72X
Tomar Ankit
Tags (4)
Christine_Li
Hi, @tomaru
Thanks for creating case to us and choosing our products.
KW45 and MCXW71 are software compatible.
The difference is mainly from production process which following different manufacture rules . KW45 is used for automotive, and MCXW71‘s aim area is for IOT industry.
So, back to your question,
We have nearly developed your KW45 SW and would like to Migrate to MCXW71 willl it be possible ? If we directly flash our SW, will it work ?
==>Yes, you can migrate from KW45 to MCXW71.
Before directly flash SW, please double confirm whether have any special macro defined for KW45 in your SW. If has, please remember to change them to adapt for MCXW71.
Please let me know whether have any other concerns on this case.
If no, please help to mark my answer as a solution for this case, so that we can close it.
And do not hesitate to create new case to us if you meet any other issue when using our product.
Christine.
Christine_Li
Hi, @tomaru
Christine.
